N2O system using cold start injector ports?
Old Aug 3, 2004 | 01:03 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Has anyone ever suggested making an N2O system that uses the cold start port on the 86-88 manifolds?
Seems like gm already did alot of work to get the ports there. All that would be left for you to do is seal the pluming to the place where the CSI sits and then to select orifices for the ports in each runner.
Maybe you couldent use them because you would have to mix the nitrous and fuel in the cold start passages (bad). Maybe you could make it a dry system and signal the ecm for more fuel through a prom burn.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
