boost and ltr's
Old Sep 16, 2004 | 11:04 PM
C&DPerformance's Avatar
Car: 89 Formula 350
Engine: 355
boost and ltr's
Will boost help a motor with long tube runners pull past 4500 or will it just add to where it already is?
Old Sep 17, 2004 | 11:46 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I believe it does. Willie shifts his LTR motor at 6000RPM.
Old Sep 18, 2004 | 08:03 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
At the track my times didn't improve shifting at 6000 comparied to when I shift at 5500, this is with SS runners and a good base but with the ****ty stock heads and cam.
Old Sep 18, 2004 | 08:29 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I've ridden in a couple of 350 TPI cars and have experimented with shift points. Both were nearly stock (sorry, I don't have details). It seemed in both cars that there's a significant power loss over 4,500 rpms. In my stock 305 TPI, 5-speed convertible. I don't notice a loss until about 5,000 rpm. In my "slightly modified" 305 TPI coupe, it's a different story. Like Robert mentioned above, it pulls to 6,000 rpm and then some. I have taken it to 6,200 with no appreciable difference in power loss. In fact, when I get my engine back into the car, I plan on an even higher shift point with the addition of a different cam (range to 6,500 rpm) and AFRs Hydra-Rev kit.
Old Sep 18, 2004 | 11:36 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
RPM's and Boost
In my 87' turbocharged GTA I did my shift's at 6800 rpms and there was a noticeable difference if shift's where made earlier. The engine surely was still making power beyond the 5500 rpms. I believe that the HSR intake with it's 58mm throttle body was the main reason for this. Heads where also ported with stock sized Manley valves and stronger double springs where also used, stock roller cam. All this was at 15psi of boost.
$750 L98
Feb 1, 2025 02:25 PM
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
