fast help involving plenum gaskets
Old Oct 1, 2004 | 09:04 PM
Incoming's Avatar
Car: 1986 Firebird T/A Streetracer
Engine: V8 350TPI
Transmission: Modified 700R4
I pulled off my 350tpi plenum to polish and port it and i broke the gaskets when i pulled it off... if i tighten the runners into the plenum real tight will i be safe to drive it a couple of days without the gaskets? Otherwise would autozone have them???
If all else fails where do i order them from... thanks wes
Old Oct 2, 2004 | 02:24 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
You would almost certainly have a vacuum leak. I wouldn't do it. Back when I had my '85 Z, I think I got a set of gaskets from Schucks, they even had them in stock!
Old Oct 2, 2004 | 10:11 PM
C&DPerformance's Avatar
Car: 89 Formula 350
Engine: 355
Yeah they will have them, but most of the time you have to get a complete intake set.
Old Oct 3, 2004 | 12:23 AM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Yes, autozone will have them. It comes in a set that will run you about $26 and includes all gaskets for runner to plenum/intake, new intake gaskets, TB gaskets, and new o-rings. I wouldn't crank down on that bolt period since it's aluminum, you're bound to mess up something by overtorquing.
Old Oct 3, 2004 | 06:51 AM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
If ya need to, you can reuse the broken one with a bit of silicone on the breaks, then it'll hold ya till you get new ones. Like previosly said, you'll have massive leaks if you try running w/o them.
Old Oct 12, 2004 | 05:06 PM
83 Crossfire TA's Avatar
Any decent sealant will work in their place also... I use some non hardening stuff instead of gaskets.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
toronto formula
19
Oct 6, 2015 12:27 PM
