delete pulley
Old Oct 6, 2004 | 10:43 AM
Incoming's Avatar
Car: 1986 Firebird T/A Streetracer
Engine: V8 350TPI
Transmission: Modified 700R4
delete pulley
not sure if its right catogory but what delete pulley would fit my 86 firebird? all the pulleys ive seen have the wide belts i have a little v shaped belt.. i need one badly! my car is dead without it...
thnx wes
Old Oct 6, 2004 | 10:59 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: delete pulley
thnx wes
what are you deleting -- there are two delete pulleys available, one for AC, the other one for the smog pump. And yes, both are made for the single serpentine belt setup, a very worthwhile upgrade.
With the v-belts, you should be able to simply remove whatever accessory belt you like without problem.
Old Oct 6, 2004 | 11:44 AM
Incoming's Avatar
Engine: V8 350TPI
my serpentine goes around my alternator on the passanger side the compressor belt goes around another 3 pulleys on the driver side... so im guessing it has to be important... look at picture below where my finger is is where the compressor pulley was i dont know what to do
Old Oct 6, 2004 | 01:51 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
looks like all you need in that picture is a pair of wire clippers to snip that belt off. if you absolutely positively have to have a belt to run on the empty groove just to feel better. then get a shorter belt that goes around the same stuff without the A/C compressor. that is what I did, I ran that way for a while.
I eventually deleted the smog pump and did the same thing. then I ran that way for a while.
the last item was the power steering pump. when I deleted it all I had left was the single wide belt that went around the crank waterpump and alternator. that is what the car runs now.
Old Oct 7, 2004 | 10:55 AM
Incoming's Avatar
Engine: V8 350TPI
in the picture that belt goes around all 3 other pulleys do those pulleys turn themselves? can i try to start my car and see if they all turn or will that mess things up?
Old Oct 7, 2004 | 01:25 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
you run the serpentine (which allows the crank to turn the waterpump and alternator)
you run a single V belt from the crank to run the power steeriing pump
if you wish to continue to run a smog pump for emissions, then you will need a second V-belt from the crank to run that as well
Old Oct 8, 2004 | 02:46 AM
Incoming's Avatar
Engine: V8 350TPI
ok then everything should be alright as far as the belts go... i dont understand why the compressor belt would go around 3 pulleys instead of a single but... if u say it doesnt make a diffrence i can only take a experts advice over my own
appretiate it.
westley
Old Oct 8, 2004 | 02:47 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
its just the way GM did it
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
