nos??? stock TPI
Old Oct 28, 2004 | 08:11 PM
350f_bird's Avatar
Car: 91 firebird formula 350 or 94 grand am se
Engine: 350 or 3.1
Transmission: 700r4 or what ever a grand am has
nos??? stock TPI
How much nos can a STOCK tpi (l98) motor take?????
Old Oct 29, 2004 | 08:54 AM
jonarotz's Avatar
Car: 91 Z28
In my NOS 5151 kit (I think thats the #) It says you can use a 150 shot. I am sure it will take it as long as everything is in good order. Make sure your fuel pump is up to snuff before spraying it. Depending on your climate you might need to use different jets. Try to jet towards the rich side of things. It is always better to run rich than melt a piston.
Since you are asking this question I assume that you have never used nitrous before, I would start off with a smaller shot that way you will have an idea on how the car will react.
Old Nov 7, 2004 | 01:49 PM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
NOS kits are generally jetted fat for just that reason... They want you to bolt it on and have fun not go BOOM! You should be ok with the stock kit but I would suggest adding a nitrous pressure gauge in the drivers line of sight as well as an adjustable fuel press regulator w/ gauge... These are your primary and best tuning tools. Good luck!
Josh,
J.S. Performance
215-783-4645
Old Nov 9, 2004 | 08:45 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
i run 125 all day long on a stock 91 5.7z. i have most of the saftey shtff.. fp sw, TPS sw, window sw, and pulled out some timing.. will be lowering plugs range and going to a 150 ish shot.
Old Nov 9, 2004 | 08:50 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
if the motor has less than 100k on it you can get away with 100shot, anything pass 100k with stock internals would be a ticking time-bomb.
Old Nov 10, 2004 | 06:42 AM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
id agree with that.. just make sure your motor is sound as well as the feul system. it only takes a second of low fp to burn a hole in the piston. your best bet is to just research and do wht you feel confortable with and dont jerry rig it up.
-t
1992 Trans Am
May 10, 2023 07:19 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
