Finally blew up motor
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well. The motor blew up. #3 and #4 detonated. Ring kinda scuffed up the very top of the bore.
I dunno if it will hone out, and its allready .030 over. Was thinking of boring it to .040, but I cannot find the piston I want in an .040.
Anyone here have any piston advice? I'm looking for a trouf
style piston (forged of course), with aprox -11cc relief/trouf. I want the dome portion however for a quench area, so no dish pistons.
Anyone have any suggestions lemme know. TRW doesn't make the 2441 in a .040 over.
-- Joe
-- Joe
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
did you actually call TRW? and what kinda money do you want to spend? Ross Racing Pistons will hook you up with a custom set, but they are like $750 for the set.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I didn't call TRW. Will do that in the AM. I called Summit, who said "no way man"..
Doesn't seem like TRW (according to summit) believes in a 4.040" bore.
-- Joe
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Originally posted by anesthes
I think my limit for reasonable pistons is $400.00..
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by Free Bird
And that's why you can't find them. That is an odd request, as you're finding out, but anything can be made. For a price. Ross, CP, JE, will all hook you up.
the .040 oversize is VERY common, but your goal of $400 is going to make for a limited selection for sure. thats not but $50 per piston.
speedpro (formerly trw) should have something you could use, however. you just need to be somewhat flexible with your -11cc trough size.
mine are wiesco -11cc reverse dome, but they were a bit more than $400. matter of fact, their .040" over also!
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have the block completely dissasembled now, and after spending a few hours looking at it, the crap is just piston splatter. It should come off/hone out fairly easily.. I think the 4.030 bore will remain.
I'm gonna use some 64cc alum heads. Thinking trickflow, but I may go with Dart pro1.
In any event, zero decking block and using TRW-L2441F30 with a floating pin.
Sooooooooo.. That makes about 8.66:1 c/r 355 with about .045" quench.
That should allow me to run either a t-trim head unit, or a ton more spark advance..
-- Joe
Engine: 355
Axle/Gears: 4.11
Sorry, should've been more specific. The bore size is common, but everything else w/ it and only spending 400 was the tricky part.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
We hot tanked the block and then measured it.
The piston crap came off the wall, but the bottoms of those cyls where the piston rocked was pretty bad. Its goused about 4.033.
We're boring the block to 4.040"
Was thinking of running a SRP-139629 piston, which is for a 3.75" stroke crank. http://www.flatlanderracing.com/srpsbclowcomp.html
Run a 5.850" H beam rod, with a 3.480" stroke steel crank. The compression distance on the piston is 1.425".
I think that will work, and would make a 9.1:1 compression ratio motor.
Can someone check my math?
-- Joe
-- Joe
OK I understand what you are doing, the piston should fit.
1/2 stroke + rod length + compression height
1.740" + 5.850" + 1.425" = 9.015"
As long as you have the factory deck height of 9.025" (verify this) the piston will work.
For compression ratio, I use
2.1 cc for the piston being 0.010" below the deck
8.5 cc for the head gasket (4.125" bore x 0.039" thickness)
16.0 cc for the piston dish/relief
64.0 cc for the head volume
731.0 cc for swept volume from the crank
For the compression ratio,
(731.0 + 64.0 + 16.0 + 8.5 + 2.1)/ (64.0 + 16.0 + 8.5 + 2.1)
9.07:1 <--------
9.07:1 <--------
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The TRW-L2256F30 pistons I was running are installed at 9.003, and I measured between .022 and .025 at TDC, so I should be just peachy!
Here is a post of my new setup. Only thing I'm stuck on is the cam. Check it out: https://www.thirdgen.org/techbb2/sho...13#post2074513
Polo Z03
Sep 10, 2015 06:43 PM
