Curious if anyone knows the approx cost on a Twin Turbo 350 done right?
Old Nov 8, 2004 | 07:44 PM
/\/3\/\/l8l3's Avatar
I will not be able to afford this drivetrain setup in the next 2 years, but after that I can probably slap something together.
I would like to formulate an approx cost for a 350 twin turbo (BBS Designs kit) Full roller, forged pistons, steel crank, not sure on heads? Dart 2.05s? What manifold?
Old Nov 8, 2004 | 07:46 PM
biggtime's Avatar
$20,000.00 + with all new parts
Old Nov 8, 2004 | 11:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
really that much? i was thinking more like 13-15 grand with all the goodies. but could be done for 8-10 easily.
Old Nov 9, 2004 | 06:55 AM
nightrider87's Avatar
don't know what exactly you mean by done right but.
I'm going to have a total of roughly 1800 or 1900, at the most 2000 into mine including a swap to fuel injection.
Rebult junkyard .60/.63 T3s
Custom built intercooler from junkyard cores
L98 exhaust manifolds modified into turbo headers
Stealth Ram
walboro 340 high pressure
727 running $58 code
I already had a crate motor with beefier internals than stock, but lowered the compression with a set of heads I haven't included in the turbo cost. I would have been buying them even if i stayed NA so i don't think they count toward my setup, atleast for my purposes. Tack another 300 onto my total if you want to count them. I sold my old heads for 500 and purchased the protoplines for around 800.
Old Nov 9, 2004 | 09:11 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
It really depends on what's important to you, and how close to the limit of the parts you want to go... You can turbo a stock L98 for nearly free if you scrounge junkyard parts. You can build a monster motor with brand name parts and coat it all, and spend over $15k, and still not have it be an "extreme" motor... I'd set aside $5k for a pretty basic, lower end forced induction engine, another $2k for electronics if you don't go with the 730ECM (which is just about free, but has a steep learning curve). Figure $10-$15k for an average setup if you aren't super frugal...
A.
bjpotter
Jan 22, 2019 12:27 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
