Fuel Pressure Regulators
Old Nov 19, 2004 | 01:18 AM
83 Crossfire TA's Avatar
What is everybody using/what do you like?
This is not engine specific and is boost related since I’m looking for something that will withstand the higher pressures of a boosted application as well as flow a lot more fuel then most NA applications can.
I’ve managed to ruture my TPI regulator diaphragm and instead of replacing it with another I plan on going with something bigger and better (especially since eventually I plan on changing to a different manifold).
A year or so ago this would have been a no-brainer… Mallory made a 3 port rated for FI type fuel pressures and flow up to 200gph priced around $40… that one appears to be long gone, and the replacement part number (looks identical) costs 2.5x that.
So what’s a good deal and will flow a decent amount?
Old Nov 19, 2004 | 07:55 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I'm gona be running a Areomotive one
P/N's 13107
http://store.summitracing.com/defaul...eromotive+fuel
or
13101
depending if I run the rail in parallel or series.
99% sure Ill run em in Parallel.
Old Nov 20, 2004 | 06:38 AM
contactpatch's Avatar
Engine: sbc 350
Does any company use
'generally higher fuel pressure' than GM?
Ford, Mercedes, Jap stuff?
Old Nov 20, 2004 | 03:53 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I fed the right rail, crossed over with -8an, and put a supercharged grand prix (1999) reg on the end of the left rail with a 5/16 return. Works just peachy, and was cheap.
-- Joe
Old Nov 21, 2004 | 12:01 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
-- Joe
Got pics and a p/n?
Old Nov 21, 2004 | 12:13 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
You can do like preston
Old Nov 21, 2004 | 11:55 PM
I can’t really tell what he did from that pic… Looks like an aeromotive regulator and I see one of the original fuel lines connected, but beyond that I can’t tell what’s going on.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
