Underhood roots
Old Nov 21, 2004 | 01:46 PM
RsAndy's Avatar
Car: 92' RS
Engine: 350 TBI
Underhood roots
I was reading the "Camaro Performance Handbook" by David Shelby and it briefly mentioned something about a low-profile roots blower that could fit under a stock hood. Does anyone know more about this?
Old Nov 21, 2004 | 05:10 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
About the only way you are getting a roots under the hood is a magnacharger setup, and preferribly on an LS1.
Old Nov 21, 2004 | 05:33 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you can fit the wieand 144 series blowers under the stock hood wtih the correct air cleaner (i believe)
Old Nov 21, 2004 | 06:54 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Now that i would have to see to believe, IIRC my edelbrock torquer II, edel carb, and drop base cleaner didnt clear by much....
Old Nov 21, 2004 | 10:23 PM
mw66nova's Avatar
Engine: 7.0L
dimension chart for holley superchargers
Old Nov 21, 2004 | 10:25 PM
mw66nova's Avatar
Engine: 7.0L
can't seem to get the rest of the chart on here so here is the url.
http://holley.com/HiOctn/TechServ/TechInfo/SCTech3.html
Old Nov 22, 2004 | 04:54 PM
Marc 85Z28's Avatar
Read the book more carefully, it says "under the hood of a late model Camaro", and nowhere states "stock hood". It will fit under a Camaro hood, but it will require a raised cowl Camaro hood. It will fit under a 2.5" barely, with the right aircleaner - I've seen it done. But 4" would be better.
He's just stating that you can conceal a blower under a hood in a late model Camaro, and not have to cut a hole for clearance. He should have clarified that a little better. The "low profile" blower he refers to is the 142/144 blower, which is much shorter than a 6-71 or 8-71 setup.
There are a lot of important omissions in that book, not to mention that it's horribly outdated.
TheJoeY88
Dec 31, 2016 07:30 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
dimented24x7
Sep 17, 2015 06:58 AM
backtothe80s
Sep 5, 2015 12:39 AM
neekolzun
Aug 24, 2015 04:59 PM
