Which is better Roller or flat tappet for supercharger
Old Nov 22, 2004 | 08:42 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
With a roller cam isn't the cam profile curve fatter than the flat tappet?
Which Cam type is more suited for a centrifical supercharged engine?
I'm looking into building a 350 forged engine for my bird and debating between a 1 piece rms (roller) and and older style block (flat tappet).
--- Tom
Old Nov 22, 2004 | 08:55 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the type of cam you choose (roller or flat tappet) is independent of the block you use.
Old Nov 22, 2004 | 10:48 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Maybe I should have been more specific.
If I use a 1 piece rms block i will use the factory roller lifter, setup.
If I go with an older block I will probably go flat tappet.
Either way, which cam style would be better for boost.
Old Nov 22, 2004 | 11:12 AM
tommyt's Avatar
Car: 87 T/A
Engine: built NOS 350
Transmission: manual 700r4
With a blower You wont be turning very high RPM-s, probably run up to around 6500, and in that range, a hydraulic roller would work good. I would prefer the retrofit link-bar type lifters , but the factory style lifters would work ok also. Just my preference, some may think otherwise, but
either way, a hydraulic roller will be pretty good, especially if the car is mostly street driven.
Old Nov 23, 2004 | 12:53 AM
biggtime's Avatar
Rollers are always better. You can open that puppy up a ton quicker! better cylinder filling in less time.
Old Nov 23, 2004 | 05:16 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
thanks for your replies guys!
Old Nov 23, 2004 | 11:55 PM
83 Crossfire TA's Avatar
Never say always or someone will go out of their way to find the exception… on that note:
Flat tappets actually start to open valves faster (the edge of the tappet rides up on the side of the lobe faster, where the roller always contacts very close to the centerline). NA this is irrelevant since by the time the valve opens enough to get any airflow the roller is taking advantage of it’s faster available ramp. In a boosted situation, with a lot of boost, mild cam and really nice ports this all changes, and low lift numbers mean a lot more. In that situation there is actually an advantage in going flat tappet.
Real life, this is a pretty specialized situation and don't worry about it, go roller...
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
hartsmike
Oct 2, 2015 07:11 AM
dusterbd
Sep 29, 2015 08:40 AM
