what's the biggest shot you've sprayed on a dual plane ?
Old Dec 20, 2004 | 10:14 AM
MIKE 1985's Avatar
I have sprayed a 150 all the way down the track and a 210 in 1st and part of 2nd on the street. I want to spray 250, but have heard it's not recommended on an performer RPM ?
If i have to go to a single plane, i'm guessing the vic jr would be the best ?
thanks
Mike
Old Dec 23, 2004 | 09:11 AM
MIKE 1985's Avatar
no one have any experience with dual plane and nitrous ?
Old Dec 23, 2004 | 12:49 PM
onefast85's Avatar
Car: 85 camaro
Engine: 605in bbc
Transmission: powerglide
Axle/Gears: 12bolt with 4.10's
150 is all i ever tried on a dual plane.i have heard the same rumors as you about mixture problems.
Old Dec 23, 2004 | 06:55 PM
tommyt's Avatar
Car: 87 T/A
Engine: built NOS 350
Transmission: manual 700r4
I sprayed a 275 shot with a BigShot system on a 305, for a whole season, which means about 40 runs here. It had a Performer on it, not even an RPM. From what I could tell, distribution was'nt too bad, plugs looked the same, car pulled good, untill the driver overrevved it a few times and ended up breaking valvesprings. Other than that, the motor was fine. Maybee we were just lucky. I have also heard the distribution issues with dual planes, especially with Fords. Maybe they are more likely to have problems with their intake port spacing...
If this is a motor You have money into, and don't want to hurt it, I would stick to around a 200 shot, just to be safe...
Old Dec 23, 2004 | 07:37 PM
86camedcamaro's Avatar
Transmission: 350 turbo
hey tommyt what was all in that 305 to handle that? you think my stock rebuild 40 over 305 with nitrous hp cam 262 cam and performer intake/edelbrock carb can handle 100 shot?
sorry to hijack this post
Old Dec 24, 2004 | 05:07 AM
tommyt's Avatar
Car: 87 T/A
We just did this 305 as a learning mule for my buddy's car to have a motor to learn racing and driving a performance car. Durability mods were: forged pistons, head and main studs and ARP rod bolts, stainless valves. Stock cast crank and rods. We did not care it he blows it up, since it was built to see how much it will take before something gives. Held together pretty good. I have posted about this before in a different nitrous thread.
The 100 shot should be safe even on a stock rebuild, as long as fueling and timing are taken care of, IMO.
With what I know now, maybe I would try and cut a chamfer in the plenum divider if the RPM intake doesn't have it, just like the newer ones have, this should help some with the distribution, but the possibility of fuel fallout will always be greater with a dual plane running a plate style system...
Old Dec 27, 2004 | 07:17 AM
MIKE 1985's Avatar
thanks
thanks for the replies .
and no harmn on the thread, actually a great question to the thread.
Well my motor is a stock cast crank, stock rods with ARP bolts and a hyper pistons. I also have the nitrous hp 262 cam. I located a vic jr so i'll switch over to that and just sell the performer RPM, shouldn't be aproblem to get rid of a 3 mo old intake for $80.
thanks for the replies.
Mike
Old Jan 2, 2005 | 10:10 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
175 is the max. any more and it could puddle in the plenum, or not distribute evenly. you can fogg a dual plane, and not have to worry about it. but at the same time, if you are spraying big, why run a dual plane?
Old Jan 3, 2005 | 07:03 AM
MIKE 1985's Avatar
i switched it over to a vic jr
Old Jan 3, 2005 | 08:44 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
run at the track on motor yet? the victor jr will give up about .05 on the 60ft, but pick up about .08 at the big end. you may see 1mph out of it depending on your motor setup.
it will definately run better on the bottle.
Old Jan 4, 2005 | 08:23 AM
MIKE 1985's Avatar
stage 20,
I haven't as it's snowing here in Northwest , IN. Our track opens in April. I thought about fogging the dual plane to keep the driveability good, but decided the vic jr was the easier way to go.
Old Jan 4, 2005 | 12:44 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
yes sir. an intake is cheaper than all those nozzles and jets.
ZEEYAA
Apr 16, 2023 08:29 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
91 SrS
Oct 7, 2015 04:32 PM
dusterbd
Sep 29, 2015 08:40 AM
JSDaddy189
Sep 26, 2015 03:50 PM
