Supercharger Question
Old Dec 27, 2004 | 03:53 PM
klumb15's Avatar
i got a corvette TPI but its in a camaro....which kit do i buy, the one for the camaro or the one for the vette...the one for the vette is a considerable amount more than the camaro one....also i will be getting rid of my A/C if that matters...can i get the camaro kit and make it work? i'm lookin at prochargers too by the way.
Old Dec 27, 2004 | 04:09 PM
/\/3\/\/l8l3's Avatar
get a bbs twinturbo kit, it is much kewler
Old Dec 27, 2004 | 04:15 PM
klumb15's Avatar
where, how much, and can it be ran on a stock engine?
Old Dec 27, 2004 | 04:18 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
i have a L98 vet mot with a paxton charger in my 88 GTA there are some dif but i made the blower that was set up for a gta mot fit with my motor the A/C pulley is going to need to be used if you want to get ride of the compres you will need to get a pully put in it place GM sell this you can also get one off of ebay for $60 or so.but back to what eles needs to be done the water pump for a vet is longer (the pullly sticks out fearther about 1/2 or so) what i did was i got a GTA water pump and adjusted all my pullys to line up with that one with speacers if you cant the find them i got a machean guy that can make them. when you do all of that the underdrive pully that comes with the blower should line up with the supercharger pully.good luck let me know how you make out.
-GTAfanatic-
Old Dec 28, 2004 | 02:04 PM
klumb15's Avatar
so i just get a waterpump that is made for a camaro, and then it will be sittin about a 1/2 inch in closer to the engine then the rest of the pulley's, how exactly do you make spacers to suck the rest of the pulley's in...i guess i just don't understand how you move the other pulleys around to line them all line up.....so if I do this i can just use a camaro supercharger kit??? also i'm still waitin for info on that twin turbo kit that /\/3\/\/l8l3 is talking about...thanx...
Old Dec 28, 2004 | 08:13 PM
CeeDubYa's Avatar
Car: 85 Trans Am
Engine: LB9 305 TPI
Is your car V-belt? If the kit was made for a serpentine car, things aren't going to line up. I have to get all new braketry, pulleys and accessories for mine, but oh well, A/C and Smog pump aren't going back on anyways.
Old Dec 28, 2004 | 08:15 PM
klumb15's Avatar
i don't think its a vbelt....its a 90 vette motor, i beleive it came with serpentine......
Old Dec 28, 2004 | 08:20 PM
CeeDubYa's Avatar
Car: 85 Trans Am
Engine: LB9 305 TPI
Another reason the Corvette kits are more expensive, I'm thinking ProCharger for sure, and I believe Vortech as well, all of the polishing options are standard, which when you price out polishing on blower, intake tract and bracket it bumps the price up quite a bit.
When you put the Vette engine in the Camaro, did you use the Camaro accessories, or the Corvette?
Old Dec 28, 2004 | 09:25 PM
GTAfanatic's Avatar
that is a good ? but it is surpteen a mot that is yenger then 87 that was the last year for the V belts after that is the surpt. when i had my vet mot in it hade all the vet pully i got rid of most of then when i got the f-body kit one more thing i forgot to menshion is the power stearing the vet one douse not have the resver bilt into the pully it is external so i also got rid of that it was still cheaper for me to swich these things then to get the vet kitt
pic of eng when i first got car your pully are simler to this..
Old Dec 28, 2004 | 09:30 PM
GTAfanatic's Avatar
pic
Old Dec 28, 2004 | 09:32 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
i searched using dogpile for bbs turbo and found this website
http://www.bbsdesigns.net/cgi-local/...c98+1104299626
very interesting does anyone know how to get in contact with the owner? i would like to pick his brain!
Old Dec 28, 2004 | 09:35 PM
klumb15's Avatar
3200 for the 550HP kit!!! is that 550 HP on a stock TPI engine or what???thats not a bad deal at all!!!does that kit include everything, or do i have to buy other stuff to make it work??
Old Dec 29, 2004 | 12:46 AM
CeeDubYa's Avatar
Car: 85 Trans Am
Engine: LB9 305 TPI
That'll be their capability. You can't just bolt on a Turbo onto a stock engine and voila, 650HP. It'll all depend on what mods you have already and how much boost you're willing to run. If it's intercooled, a rough estimate is 7.5psi will give you ~50% increase in horsepower.
Old Dec 29, 2004 | 11:33 AM
klumb15's Avatar
i realize you can only run so much boost on a stock engine, but i'm wondering if you are able to control the boost on that particular kit??
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
