What size single turbo are you running? T6? T7?
Old Feb 7, 2005 | 04:53 PM
Formula 89 Bird's Avatar
Car: 89 Formy
Engine: 305--->TPI 350
Transmission: auto :(
I was just wondering what size turbos are people running and what hp numbers they're putting out. I have a friend offering me a TE-63 off a gn but he wants $600 for it and I don't think 63 like low boost (1.8) and higher flow (55lbs). Opinions would be great. Thanks
Old Feb 7, 2005 | 10:44 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Turbo size has a lot to do w/ airflow requirements of the motor. Efficiency etc and airflow from the turbo etc...
Old Feb 7, 2005 | 11:37 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I was running a 16G - 36lbs/min @ 2.0 PR... course, I was only running 9 psi
As of tomorrow, I'll be on a T61 @ 6psi
Old Feb 8, 2005 | 09:17 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
For comparison I'm running a TE64 and have gone as 10.69@125.8mph weighing 3550lbs.
HTH
Steve
Old Feb 9, 2005 | 07:07 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
TTA850 how much boost are you running?
I am looking at a t76gts for my 355. Talking to a few of the bigwigs over on turbomustangs that seems to be what they and I both feel work work best for the 6-10 psi I want to run...
Old Feb 9, 2005 | 02:31 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
I run about 19psi on pumpgas(93 octane)and the 10.69 run was with 25psi and racegas. It should go lower 10's this year that I've replaced the 3.08 gears with 3.42's and I hope to run more boost with the larger injectors as I was out of fuel with my old ones(had 55's now 83's).
Steve
Old Feb 9, 2005 | 09:19 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
what size turbo would u guys suggest for a 496 bbc? ive been lookin into a trubonetics T62-1 and a T76. and how well do u think these would act on a the motor with a carb? sorry to hijack the thread.
kyleb24
Aug 15, 2015 08:24 AM
wruiz
Aug 13, 2015 09:07 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
