TPI383,how do you like the HX55 ?
Old Feb 8, 2005 | 09:21 PM
Mike-91 Formula 350's Avatar
I recently got one for my project but I'm not sure about id,ing the exhaust housing.I think it's a 22cm since thats the only number a saw that I recognized.What do you have and how does it spool.And what kind of boost are you running?Thanks
Old Feb 9, 2005 | 06:41 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Sorry cant answer that for ya. Motors not done. Just collecting parts.
Might be on hold for longer now as I found a 1stGen I want to buy for a Pro-Touring/ Power Tour build.
Here are some pic's of mine if you need measurements to reference.
where did you get yours from? new/used?
http://www.cecoatings.com/images/Car...lsetHX55Turbo/
Old Feb 11, 2005 | 07:16 PM
Thanks TPI,Got mine used off a rolled 99 International with 750,000 miles.At least it's under a million.The turbo it's self seems to be OK and could probably be used to test it as is.I got the oil lines clamps piping and all.Here's a faked setup pic on my 78 Z I took for one of my friends.
Attached Thumbnails TPI383,how do you like the HX55 ?-c-my-documents-my
Old Feb 11, 2005 | 09:08 PM
83 Crossfire TA's Avatar
Joby’s friend is running one on his camaro… do a search, there’s a long thread with a build up and results.
Old Feb 11, 2005 | 10:16 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
was/id joboy running a 55? I thought it was smaller?
Old Feb 12, 2005 | 01:14 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
It was a HX50. It is almost identical to the HX55.
Old Feb 12, 2005 | 02:08 PM
Well, I guess I was a little off.
The 55 was designed as a replacement for the 50 in the same applications (funny since the 50 has a reputation for being more durable). Most of their compressor wheels, shafts and turbine wheels are interchangeable even though the housings are not. They both use the same published compressor map.
Old Feb 12, 2005 | 07:43 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Just wondering. I knew it was a large Sob like this one.
One of these days I might get around to useing it.
once again motivation has changed and Im looking to do a 67 RS.
BOTTLEDZ28
Aftermarket Vendor Review
25
Jun 7, 2008 12:41 PM
Cambridge205
Classified Ads Feedback Board
May 9, 2008 10:01 PM
FSTFBDY
Oct 8, 2006 10:13 PM
super_kev
Jul 31, 2006 12:42 PM
