Whose running a VR4 Paxton on a TPI?
Old Feb 12, 2005 | 01:46 PM
SharpZ28's Avatar
Car: 92 Z28 Camaro
Engine: 350 TPI : Supercharged
Transmission: TH700R4
I am interested in up- grading my SN2000 on my 92 Z28. It has the basic TPI bolt-ons, SLP runners, Accel intake, ported upper plenum, MSD6Al ignition, Hedman long tubes, and true dual 3'' exhaust with Flowmaster single chamber delta force mufflers. I was wondering who is running the Vr4, and how do you like it? Also my motor is stock internally with only 34k original miles, so would I be flirting with disaster by running the boost this unit can put out? Thanks for any help or in-put.
Old Mar 3, 2005 | 03:46 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
https://www.thirdgen.org/techbb2/sho...hreadid=280317 if you havent seen it already.
Old Mar 3, 2005 | 11:07 PM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
Yep, I've done the VR4 upgrade on a TPI, It's not as easy as you think.
The VR4 flows alot of air it needs 1500cfm, thats one BIG A$$
filter, you'll need 4inch ducting to the filter, and you will definatly
need a 8 rib belt setup, and thats really not big enough, 10 rib would be better, I still have a Belt slipping issue: (http://www.superchargerhelp.com/showthread.php?t=7190)
I'm only getting 11 to 12 psi before the belt slips.
You'll need a big exhaust, and need to regap your Spark plugs
down to .030 or less or you will just blow out the spark.
and this is the big one: enough fuel and a proper tune,
I found that my combo liked an AFR of 12.7 and a max timing of 23deg.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
