Miniram And NOS questions
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Yes, and a search would've told you.
Some people have distribution problems w/ a plate kit. I'd go w/ a fogger when using that intake.
Id use a plate with that intake. Heres why. The runners are shorter on the Miniram, than they are on a TPI, or S/R. Nitrous is lighter than fuel, and yes there are fuel puddle problems in all intakes, not just the ones mentioned. The farther the fuel and nitrous mix has to travel, the more chance of the heavier fuel droplets will fall out of the mix. You can use the plate system that any one of the nitrous companys sells, and save the cash, and the labor, and complexity of the fogger system. You can always spend the money on a fuel pump upgrade, which in my opinion would be money well spent.
LT1Formula
20
Nov 14, 2015 12:02 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
