nx nitrous questions on a tpi
Old Mar 12, 2005 | 09:32 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
nitrous questions will someone help?
i have a 91 tpi motor from a z28 in my 92 chevy truck, has been gon through, .40 over bigger cam-comp cam 212-218, 487-495, 264-270, comp cams 1.52 rollers, 24lbs, edelbrock base, ported slps, bbk52mm, ported plenum, i bought a used 15lb nx setup, with a heater, purge valve, ect, it came with the shark nozzle, well i dont want to put a hole in my nice ported plenum, could i use a nos plate and run it that way? or what is the best way to do it? also what shot should i run, 35-150? i aslo have a b&m 2200 hole shot and i need to know if im goin to brake it with running nitrous? should i install i window switch so that it wont come on tell like 2500 then shut off at like 5000? what do you all think?
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
