draw or blow through with TBI
Old Mar 12, 2005 | 09:47 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
wich would be better for TBI, I'm not looking for 500hp so which would be better
Old Mar 13, 2005 | 01:30 AM
NEEDforSPEED's Avatar
blow through, good luck with getting that to work with TBI,
theres really no way of tuning it, others have played around with the idea tho, try and search see what you find
Old Mar 13, 2005 | 01:37 AM
AustinT's Avatar
What are some problems with getting it to work with a Tbi? I planned on doing the same thing. Using a holley 4 barrel tbi with a 749 ecm.
Old Mar 13, 2005 | 03:07 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Draw thru:
You would have to use a 2-bar MAP sensor and put it between the turbo and intake, not between the TBI and the turbo like it would be if you used the stock vacuum port.
You would also need a turbo with special seals.
You could not use an intercooler.
Blow thru:
You have to modify the TBI for boost ( Easy, drill two small holes ). The holley 4 barrel tbi might not need any modification.
Use a 2-bar MAP-sensor or a progressive fuel pressure regulator.
You can use any turbo if the size is right.
You can use an intercooler.
Conclusion : build a blow thru if you want to turbocharge it.
To make tuning easier you could use a non-stock ECU, like megasquirt. Tuning a blow-thru TBI is no different from tuning a TPI or any other multi port injection system.
Old Mar 13, 2005 | 09:44 AM
AustinT's Avatar
Sorry I do not mean to hijack your post my hp goal is the same using a tbi.
Thanks JoBy for the feedback. How do you keep the air from leaking around the throttle shafts?
Old Mar 14, 2005 | 02:38 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
You will find the instructions om how to modify a TBI for boost in an installation manual for a Vortech supercharger kit.
http://www.vortechsuperchargers.com/support/
This is the instreuction for a GM Truck (1988-1993 7.4 TBI Truck/SUV). Look at page 16. Then you have to port a channel in the intake or the TBI so the new hole sees engine vacuum when the throttle is closed. In the Vortech kit that is done in the throttle body spacer block on page 15.
http://www.vortechsuperchargers.com/...gc4gg218im.pdf
Old Mar 15, 2005 | 02:01 AM
83 Crossfire TA's Avatar
Essentially, there are no advantages to draw through over blow through with a TBI (there are slight tuning advantages if it were a carb). The only real issue with blowing through one is to deliver enough fuel to the engine under boost. You have 3 choices:
- add fuel pressure with boost using an external RRFPR or FMU
- program the ECM (you’ll probably end up running the biggest injectors that you can find at a higher then stock pressure to have any chance keeping up with the boost
- use an auxiliary setup like vortech uses for their superchargers, a super fueler or something similar
BLK87Z
Sep 18, 2015 11:29 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
90formulaVortec
Sep 3, 2015 09:26 AM
