Serpentine belt swap to make way for ATI Procharger
Old Apr 11, 2005 | 11:36 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Hey guys I need to get rid of my multi belt setup on my '86 and swap to the later serpentine belt setup. I found a post linked to sethirdgen.org outlining the procedure and it doesnt seem that bad. my problem is, there are no TPI cars in the junkyards around here so i am having trouble finding brackets. I E-mailed hawks and they can hook me up but i wanted to look locally before i paid shipping and dealt with all that. I know brackets off a TBI v6 or v8 truck wont work, but will the serpentine setup off a TBI 305 camaro or firebird work? Thanks for the info.
Old Apr 11, 2005 | 05:52 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
look for tbi 305-350 caprices they are the same (usually have the high amp alt but, that's just an extra bracket which you can sell to some one with a big system
yes, the 305 tbi cars have the same
Old Apr 11, 2005 | 07:53 PM
soon2bcharged's Avatar
Car: trans am
Engine: 350 tpi
I have seen a complete kit for 600$ that comes with the belt, pulleys, water pump, powersteering pump, alt, and bracets and tensioner best of all everthing is new NOT used. it was at some fbody dot com place. sorry i dont have the name but there out there...
Old Apr 12, 2005 | 11:20 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
sweet that broadens my search quite a bit. thanks for the info.
Old Apr 12, 2005 | 05:15 PM
Car: trans am
Engine: 350 tpi
found the site
the site that has the kit is fbodymotorsports.com
Old Apr 12, 2005 | 09:50 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I believe the GM parts direct site has the GM serp. setup without the a/c unit as well- I believe it comes with a ac delete pulley.
http://www.gmpartsdirect.com/results...umber=12497698
Also check Jegs- they sell the GM serp setup sans ac unit for a very reasonable price. All new, all fasteners and brackets, AIR, water pump p/s etc...
It is a nice kit from GM.
S-D
Although, you can often find a hogged out 305 complete for the same price- but then you have to clean the components and may have to buy new accesories.
Old Apr 12, 2005 | 09:59 PM
Car: 1991 RS
Jegs
http://www.jegs.com/cgi-bin/ncommerc...77&prmenbr=361
Also- if you just need the brackets, I see them on eBay from time to time. Usually overpriced
S-D
1992 Trans Am
May 10, 2023 07:19 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
