seriously considering spray for mildly moded 305 tpi
Old Apr 14, 2005 | 04:06 PM
stangStomper83's Avatar
Car: 89 formula and my late 86 iroc R.I.P girl
Engine: 89 firebird formula-305 tbi,86 iroc 305 tpi
Transmission: both 700r4
i want to go faster. considering n2o. i have a rebuilt LB9 305 tpi out of a 86 iroc in my 89 formula. i want to use the spacer plate system (the one were n2o is sprayed in via plate between plenum and throtle body) need to know who makes these kits and the pros and cons. how many of you guys use these kits and is in really worth the risk. how much is to much.
mods on my car are as follows
cold air intake
adjustable fuel pressure regulator set at 49.5 psi
crane cams compucam (this is a mild cam with a little more ***** then the stock one)
eldlebrock headers and y-pipe
3in exhaust
hyperthech cap and coil with 8.5mm wires and double plat plugs
3.73 rear gearing
no a\c if u consider that a mod
Old Apr 14, 2005 | 06:00 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Yeah I kinda want to know also, only difference is I have a carb, I want to get one of those plates that go in between the carb and the intake manifold. The only mods on the engine i have are headers, and thats not really the engine. I have a 350, runs pretty solid, what kind of shot should I use and still be in that nice big pretty "safe zone" Its my daily driver so i dont feel like blowing a piston through my hood or something to that effect.
Old Apr 14, 2005 | 10:11 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have run dry nitrous on my car. 2 bottles worth(30 passes) and good so far.
75hp shot. Really feels good but be safe, get a better fuel pump, a fuel pressure gauge, better gas and make sure you start small and work your way up.
Good luck
LB9GTA
Old Apr 15, 2005 | 04:25 AM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Thanks for the input, I was originally going to try a 100 shot but ill be safe and just use a 75.
you probably just saved my engine, haha
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
