Nitrous and Manual Transmission?
Subscribe
Apr 21, 2005 | 08:56 AM
Is there anything special I need to do to run nitrous and a manual transmission? I've heard some people say that you don't want to hit the nitrous when the motor is unloaded. While I do lift when I shift a little, I'm sure sometimes I am back on the throttle before the clutch is fully engaged. What happens if I miss a shift as well?
Thanks for the help...hopefuly those with manuals and nitrous will chime in.
Nick
Reply 0
Apr 21, 2005 | 09:43 AM
You can run the WOT switch in series with a 'clutch fully up' switch.
It is not good to miss a shift ...
Reply 0
Apr 21, 2005 | 06:23 PM
You need a rpm window activation switch. I just hooked one up today on my car. It uses MSD pills to adjust what you want the N20 to come on and off at.
Reply 0
Apr 21, 2005 | 10:29 PM
http://harlan-engineering.com/
http://www.bmnracetech.com/
I was just checking these window switchs out yesterday, the harlan one at $50 seems to be hard to beat.
Reply 0
Apr 28, 2005 | 01:00 PM
I'm going to be running an Mallroy Hyfire VI which has a window switch already built in....is this really all I need?
Reply 0
Apr 28, 2005 | 03:33 PM
The window switch is the bigest needed safety device for running nitrous.Expecially a manual car.
Dave
Reply 0
Apr 28, 2005 | 03:37 PM
run a WOT switch, clutch up switch and a window switch...... thats about all you can do.
Reply 0
Apr 28, 2005 | 03:38 PM
FUG! harlen closed his store
i wanted a LS1 2step from him....
Reply 0
Subscribe
