Would a roots 177 (not 142) work on a 350?
Old Apr 24, 2005 | 10:01 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
I see the 142's advertised for 350 sized engines and the 177's are for larger displacement like 383, 400. I imagine because the 177 moves a lot more air..
My question is would it be possible to use a 177 on a pump gas mild cam 350 by using larger heads, lower compression, swapping pulleys, or a combination of these?
Old Apr 25, 2005 | 12:37 PM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
yeah , why not?
i think its okay to use larger blowers, too small would be a problem, but i dont think you can go too big.
With too big of turbo's you can get a problem with turbo-lag, but thats not with blowers.
gotta love blowers!
in my opinion the 177 would work great.
Old Apr 25, 2005 | 08:05 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes, thats what they sell it for.
Old Apr 25, 2005 | 09:14 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Like stated earlier it shouldn't be a problem. A 144 to 177 ci isn't that great of change. Going slightly bigger would allow more upgrades possible in the future. You could get a tad more out of the combination before worrying about the blower being too small.
There is a certain point you can go a little too big. That's only if you try to go outrageously big. It's due to the blowers actually have a small amount of leakage at low speeds. So to put a huge blower like a 8-71 on a 305 it would have to be turning slower than if you used a 4-71. There is supposely greater clearances for leakage to occur.
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
djmarch
Aug 11, 2015 10:22 AM
milk
Aug 10, 2015 06:26 PM
