$58 any one running a intercooler fan?
Old May 1, 2005 | 07:57 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
has anyone here done this?
I was thinking of running an intercooler fan using the output in the $58 code. I remember there is a table for this and unless someone here has done it I think I will have to check the wiring to make sure it is not my second cooling fan. or if it is just run both off fan 1 and use fan 2 for the intercooler. what do you guys think?
BTW I will be using relays and such like you should I just thought since ATI has the intercooler on it's side It would be pretty easy to put a fan on top as a puller fan.
Old May 2, 2005 | 07:22 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: $58 any one running a intercooler fan?
I'm using that output to control both my normal fans..
-- Joe
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Terrell351
Jun 13, 2021 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
TA8487
Aug 16, 2015 12:21 PM
