Is the charger bad?...
Old May 5, 2005 | 02:08 PM
sam's Avatar
sam
If someone has a supercharger trying to sell for 650, but cant turn the pulley by hand but it will turn when a wrench is used...
Is this normal or an indication to stay asway?
Thanks,
Sam
Old May 5, 2005 | 08:59 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
its cooked
Old May 5, 2005 | 09:03 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
let me guess hum? paxton?
Old May 6, 2005 | 02:25 AM
sam's Avatar
sam
paxton is it!
So I cant rebuild it? Buy parts and fix?
Old May 6, 2005 | 11:24 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
The Paxton SN series ball drive blower are easy to rebuild.
Cost $300.00 or less to rebuild if you do it your self.
A SN Ball drive Supercharger set up correctly normally takes 30 to 50 in/lb's
at the pulley to turn (most likely can't be turned by hand)
When you do turn it it should turn smoothly and not rachety, if
it's not smoothly turning then it most likely needs repaired.
Old May 6, 2005 | 02:36 PM
sam's Avatar
sam
thanks, then i guess it might be okay and the person might be weak.
One last thing, it came off a 86 corvette tpi. will it bolt on to a 88 305 tpi? Or do i have to modify alot?
Thanks,
Sam
KCG
Jun 24, 2020 04:33 AM
BumpaD82
Feb 26, 2016 02:57 PM
Stryker412
Sep 20, 2015 06:59 PM
gta892000
Sep 16, 2015 12:40 AM
Formula_88AE
Sep 3, 2015 01:47 PM
