390hp N/A + 100hp nitrous
Old May 25, 2005 | 11:00 AM
Flfinn's Avatar
Car: GTA '88
Engine: 420 Dart SHP
I have about 390hp out of a T-rammed 355, 328hp to the ground. The bottom end is fully balanced, with stock rods (rod sides are polished) and with ARP-bolts, KB's hyper pistons (with nitrousready piston ring end cap), heads are AFR195cc's, 255lph fuelpump, 30lbsh SVO's. T-56, stock rebuild B&W posi rearend.
the kit is NX's 50-150hp 1-stage wet kit, controlled by haltech E6GMX. It controls nitrous start/stop rpm, ign retard, min start engine temp etc.
Will the engine survive continiously this kind of nitrous "abuse"?
Old May 25, 2005 | 11:10 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
No engine will survive nitrous abuse. By abuse I mean detonation, no fuel ect.
If you set the kit of correctly I think you will be ok. Except maybe the rods. What kind of rod bolts do you have?
Old May 25, 2005 | 11:34 AM
Flfinn's Avatar
Car: GTA '88
ARP-rod bolts.
Old May 25, 2005 | 10:26 PM
NOSFEDGTA's Avatar
Re: 390hp N/A + 100hp nitrous
as long as the tune is good. that motor will survive all day on 100-150.
I ran a 355 with stock crank, rods "with arp bolts", probe pistons and dura moly rings and sprayed 200 for 2 years. it now resides in my friends car and he has been spraying it with 200 for almost 1 year now....
Old May 26, 2005 | 04:47 PM
caribbean 85's Avatar
Car: 1985 Berlinetta (drag only)
Engine: 383ci chevy
Transmission: TH-350 T-brake
Axle/Gears: 9 inch Ford & 4.56 gears
I agree - stop worrying - just make sure you put all the safety features in place - WOT switch at least, a window switch if possible, adequate fuel - preferably a dedicated fuel pump(if applicable) low fuel pressure switch etc.
Also wire your system properly and enjoy the squeeze!!!!!
There is nothing like a good nitrous assisted pass -
except maybe a heavy nitrous assisted pass
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
ericjon262
Sep 11, 2015 06:07 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Biochem
Carburetors
Nov 22, 2000 09:37 PM
