vortec heads and cent. blower???
Old May 25, 2005 | 10:21 PM
92RSMuscle's Avatar
how do vortec heads respond to boost? i can aquire a procharger, but i have a set of vortec heads, how much will they hurt me?
mike
Old May 26, 2005 | 12:25 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
should work good
Old May 26, 2005 | 11:24 AM
92RSMuscle's Avatar
so my 1.94 and 1.60 vortecs with exhaust porting, and a dual plane and headers should work well with a procharger running 8-9 lbs of boost non intercooled?
Old May 27, 2005 | 02:02 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
which procharger unit you getting
To run 8-9 lbs of boost non ic on pump gas i'd say you'll need 8.5cr MAX.
I'd start off with 5-6lbs till you get a handel on the tune then swap pulleys for more boost
DEPENDING, on cam and sc unit it shouldn't be very hard to get 500fwhp
Old May 27, 2005 | 02:29 AM
BlownBird's Avatar
With a blow through carb setup you will be fine with that boost level. The fuel pulled from the carb has a cooling affect on the incoming air.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
