Whats an Air/Fuel Ratio Meter?
Old Jul 27, 2005 | 01:39 AM
GreenChevelleSS's Avatar
Car: 1970 Chevelle SS 396
Engine: 414ci Big Block Chevy
Transmission: Muncie Turbo Hydromatic 400
What the title say.... Help, whats it do how does it work? where does it go?
Old Jul 27, 2005 | 01:58 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
An air fuel meter measures you air fuel mixture. It tells you if your running lean or rich. It has an o2 sensor that is installed into your exhuast.
Old Jul 27, 2005 | 05:49 PM
blown3rdgen's Avatar
If you are going to get one, spend the money for a wide band set up. (LM1, etc)
The others react too slow and are only accurate at/near stoich (14.7). Mainly just eye candy.
Could also use a digital voltmeter on a standard o2
Matt
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
