which motor oil for turbo?
Old Aug 4, 2005 | 02:14 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Which weight of motor oil does anyone recommend for a twin turbo tpi 355? I read somewhere that the Twin Turbo Callaway Corvettes in the 80's used 20w-50. I'm also running an oil cooler if that makes any difference.
Old Aug 4, 2005 | 02:28 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
10w40 would be my generic answer...
the quality of the oil would be more important then the weight.... with the heatsoaking alot of turbos have, and the worry of coking, i would run a full, real synthetic.... Mobil 1 would be my choice... and if its a fresh built motor, id run 5w30 in it.
if you let it idle down, and change the oil often, you can use any high quality ASH based oil....
just stay far far away from wax based oils like penzoil, walmarts, ect...
Old Aug 4, 2005 | 06:03 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
I run 15w-50 mobil 1 synthetic
Old Aug 6, 2005 | 08:11 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
15w50 Mobil 1 here, too.
Old Aug 24, 2005 | 10:18 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
well according to turbo guru's thinner weight oil allows them to operate more efficiently and spool faster. How much faster is the real question though.
Old Aug 26, 2005 | 08:44 AM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
you wouldn't notice the difference its that small, but i still run 5W-30 in every turbo car i own.... plus amsoil makes a sinthetic turbo formulated oil which is my first choice
Street Lethal
Apr 30, 2019 12:14 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
