Cali emissions legal blower set up
Old Aug 21, 2005 | 02:21 AM
primer84z's Avatar
Can anyone point me in the right direction for a CALI emission legal supercharger system on a TPI? Also is there any proven combinations out there that are the most trusted? I need a complete list of EVERYTHING that I will need, (injectors, prom, etc) This will be my first attempt at forced induction and I want to get started right. The car will probably be a 5.0 tpi, but after the motor blows, it will be a 5.7. Will the fuel system be interchangeable? Or should i just buy the 5.0 tpi and build the supercharged 5.7 in the garage and swap it in? Will i need a different computer? Thanks.
Old Aug 21, 2005 | 03:12 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
vortech supercharger is legal. adds almost 100hp and 100 ft/lbs to a 350TPI, and includes everything you need to make it work ni the kit.
Old Aug 21, 2005 | 05:07 PM
primer84z's Avatar
sounds good. Now if I installed it on a 5.0 and it blew, everything would swap over to the 5.7, correct?
Old Aug 22, 2005 | 10:45 AM
jimp2001's Avatar
Engine: LO3 305 TBI
provided you keep the tpi setup, yeah
Old Aug 22, 2005 | 03:56 PM
KS91Z28's Avatar
ProCharger is CARB cert and will work on the 5.0 and 5.7 also.
Old Aug 22, 2005 | 08:34 PM
primer84z's Avatar
Sweet. Thanks guys.
Frozer!!!
Jan 19, 2024 04:55 PM
onefreakz
May 14, 2018 12:15 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mhatfield 14
Aug 15, 2015 10:47 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
