What do you guys run for a tpi intake boot?
Old Oct 4, 2005 | 09:58 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I figured that you guys would be the most knowledgably on something like this, so...
I recently installed a ram air hood on my car. I love the hood, but the air box assembly cries ******* in its current state. The piece of rubber that ram air hood (.com) recommends is fine for speed density applications, but it looks extremely restrictive when you try to jam a 4” long MAF sensor between the air box and the throttle body.
In other words, I want a piece of rubber that will fit on the throttle body (oval) then go down to a 3-3.5" round hole in about 2-3 inches.
Thanks in advance
Old Oct 4, 2005 | 10:59 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Why rubber? You could easily make that out of any other types of material or even buy something that would fit that application in aluminum tubing or something.
Old Oct 4, 2005 | 11:08 PM
Gummie's Avatar
Car: 88 GTA
I said rubber because it would be the most flexable. I'm not sure what the exact length has to be and rubber can be stretched/compacted to cover my margins of error. Where would I be able to buy something like that in aluminum?
I don't really care what it is as long as it works.
Old Oct 4, 2005 | 11:19 PM
TragicPark's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L V8 TPI
I went to a hardware store and got some rubber pieces from the plumbing aisle. It works great. No issues whatsoever once you get the piece on the throttle body and the maf sensor.
Old Oct 5, 2005 | 08:45 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
IIRC, the throttlebody connection works with a 4" ID rubber hose. To neck it down, I ended up welding an aluminum reducer.
Old Oct 5, 2005 | 01:06 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I bought a black silicone reducer on ebay 4" to 3". It was only 3" long. It was $12. I used it to connect an aluminum intake pipe to the throttlebody. After I slid the reducer over the TB and the aluminum pipe, the total distance between the pipe and TB was like 1".
Old Oct 5, 2005 | 10:20 PM
Gummie's Avatar
Car: 88 GTA
Thanks all for the replies. I will look where you sugested, starting with the hardware store since it is the closest.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
86IROC112
Aug 17, 2015 02:00 PM
squiggy2
Aug 9, 2015 09:30 PM
