Question For Anyone Running Ford TB with GM ECM
Old Oct 9, 2005 | 10:15 PM
LT1guy's Avatar
Car: 1987 Trans Am
Since the Ford TPS has a narrower adjustment range than the GM one, how do you set it? I know GM should be around .55 volts to 4.5 volts at WOT, and the Ford sensor's range is from aprox 1 volt to 4.5 volts. I set the TPS to .55v with the throttle closed, but can't get a higher reading at WOT than 4.07, even with the TPS massively slotted. Any ideas? The GM TPS is a completely different design, so thats not going to work. Is this going to take custom programming to fix?
InfinityShade
Aug 22, 2015 08:00 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
marcusaw
Aug 10, 2015 08:13 AM
