What compression Ratio?
Old Oct 13, 2005 | 02:28 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its a 89 block, studded 2 bolt main, stock crank, H beams, Wiseco PIstons. All internally balanced. Stock 64CC L98 Cast Heads. Will be using the ATI 9-12 lbs range. Probebly see track twice a year and mostly show car. Buddy works at Wiseco so hes making me up the slugs. I just need to know what to go with. 8:5:1 8:8:1 9:0:1?
PS We will have a 2 core intercooler and run 94 Sunoco.
Old Oct 16, 2005 | 12:09 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
btt
Old Oct 16, 2005 | 03:17 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
anyone should work fine
Old Oct 26, 2005 | 01:50 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
8:5:1...you'll be able to run more boost with more room against detonation especially with the intercooler.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
