L31 headed 305 with boost
Old Nov 19, 2005 | 07:48 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Im thinking about putting L31's on my 305 and running a vortech supercharger. Does anyone see a problem with this?
Old Nov 19, 2005 | 09:00 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
should be fine...whats your lift at the valve
Old Nov 19, 2005 | 09:04 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I have no idea, stock cam. Havent bought the heads yet. Where would you think the cr would be with 64cc 350 heads on a 305? 8.5 or so?
Old Nov 20, 2005 | 03:08 AM
Z69's Avatar
Z69
Most vortecs are 62cc
Old Nov 20, 2005 | 03:25 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
64cc if its off a 350.
Old Nov 20, 2005 | 04:00 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
With that lower compression, any ideas what would be a safe boost?
Old Nov 21, 2005 | 01:50 AM
Z69's Avatar
Z69
Uh, I have a set, measured them... 62cc- for a 350
Old Nov 21, 2005 | 02:32 AM
7plagues's Avatar
well... gm performance lists stock vortec heads as 64cc. go figure.
Old Nov 21, 2005 | 09:41 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
What? Thats news to my eyes.
Old Nov 21, 2005 | 10:47 AM
Z69's Avatar
Z69
When the swap first got popular.
All the people I know of that checked got 62.
It's not like one guy got 61 and another got 63.
Just 62.
Seeing as they are bigger than his stock 305's, no big deal.
But to me it was. I ended up at 10.9 CR on my 383.
I had a big enough cam so it worked. But if you try to optimize it and shoot for x CR. And then find out about the smaller than listed chamber.....
Old Nov 23, 2005 | 10:42 AM
Damon's Avatar
If you used a GMPP .028" composite head gasket and we assumed 62cc for the heads you'd be right at 8.6:1. I think that would be fine for a modest supercharger application assuming you never run lean and never over-do it with the ignition timing.
Old Nov 23, 2005 | 11:28 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Ok, I plan on using water/alcohol injection to further help ward off any detonation. Still using stock pistons. Not too much boost, just enough to get me around 350 hp.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
