turbo compression
Old Nov 30, 2005 | 09:54 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
turbo compression
just looking for a good compression for a 406 that will run a 176 or 88 turbo is 8-1 to low
Old Nov 30, 2005 | 11:46 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Do a search on google for ray hall calculator. It will give the comp. ratio.
That sounds like a big motor & big turbo for a first time turbo app.
The comp. ratio depends on gas, intercooler, water injection, etc. You probably need to post more info on the setup to get a reasonable answer.
Old Dec 2, 2005 | 12:30 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
A good compression ratio that everyone seems to agree on is 8.5 for boost. A thread debating it is on the turbomustangs forum and is pretty good.
http://www.turbomustangs.com/smf/ind...63.0;topicseen
Old Dec 2, 2005 | 03:08 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Im ~8 to 1 before the turbo kicks in... However When I run low boost(street setting) I have to run a hotter plug than when Im in race mode..
FormulasOnly
Jul 23, 2018 08:47 AM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
