NE1 with NOS TB on non LT1 engine?
Old Dec 26, 2005 | 10:09 AM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
NE1 with NOS TB on non LT1 intake?
Hey,
Anybody have a NOS throttle body with the built in spray passages running on a TPI or Holley stealth ram intake? Can I use a throttle body from a LT1 on a TPI or HSR?
Old Jan 9, 2006 | 06:13 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I've used 2 different LS1 style spray plates on my L98 and they both fit. The NOS is the way to go if you have a larger than stock throttle body, the other one I used had a spray bar for fuel at the top of the plate and it got in the way of a 52mm. Just make sure you get your TV cable reset when you put the plate in.
Old Jan 11, 2006 | 07:18 PM
I THINK YOU MISUNDERSTOOD ME. NOS makes a throttle body. Like the whole thing with brackets and bores and throttle plates and everything. It has built it passages for spray. It replaces youe throttle body. It says it will fit an LT1 intake. I am wondering if it will also fit a Holley SR or a tuned port intake.
Old Jan 11, 2006 | 07:58 PM
It should but the LT1's throttle cable and TV cable hookups are substantially different. I'm sure it could be fabbed up to work.
Old Jan 11, 2006 | 07:59 PM
and I used LT1 plates NOT LS1 plates, sorry about the typo.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
