powershot plate
Old Dec 30, 2005 | 08:04 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
powershot plate
has anybody or do you know if a powershot plate can be made adjustable? can i just change the fittings on the plate and add some jets?
Old Dec 31, 2005 | 12:22 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
hey craig the kit i sold you isnt a powershot plate. the guy that sold me the kit used 100 , 125 and 150 jets. N.O.S. says the powershot kit is preset to 125. take the hard lines off the plate and see if a set of jets fall out.
Old Dec 31, 2005 | 04:05 PM
craig's Avatar
Car: 86 camaro
hi tim, i took the fitting off and it just has a ferrul on the steel line into the plate.i've got a dual carb setup so i wanted adjustable plates.if i run 2 powershot plates thru 1 powershot solenoid will that make the total less than 125hp each?i don't think my bottom end will handle 250 hp. maybe its time for a rebuild.
Old Dec 31, 2005 | 04:18 PM
TURBOMAGNUM's Avatar
I believe the powershot plate has less oriffices on the spray bar and no jets compared to a cheater plate. so you would have to drill more holes in the spray bar.
I would try to find adjustable plates and 2 sets of solenoids, just to be safe.
Old Dec 31, 2005 | 06:49 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
if you use 2 plates on 1 soleniod you will run less then 125 shot. if you run 2 plates youll need to run a distrobution block from NOS to the plates or from the distrobution block to 2 nitrous solenoids then to the plates.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
