Bov?
Old Jan 10, 2006 | 05:40 PM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
Bov?
What kind of BOV will I need for my 305TPI with a Garrett tp38? My friend says I need a 12:1 BOV. Do I need any specific kind?
Old Jan 10, 2006 | 10:37 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
How much money do you want to spend? You can get a cheap DSM or VW blow off valve for like 20 to 30 bucks. Someone may correct me but I dont think there are different sized blow off valves. In any case it wont matter for what your doing.
Old Jan 11, 2006 | 12:51 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I think he meant a 12:1 FMU. As for the BOV, you can run a stock CBV or an aftermarket BOV.
Old Jan 11, 2006 | 04:54 AM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
Will this eliminate the need for bigger injectors?
Old Jan 11, 2006 | 04:55 AM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
I only plan on running about 6-7 psi.
Old Jan 11, 2006 | 07:36 AM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
FMU 12:1 means for every LB of boost, you add 12LBS fuel pressure. So if you start out at 43psi fuel pressure, you boost 7psi, so 7X12=84.00 + orig 43= 127psi fuel pressure. Your stock pump will never handle this and possibly your injectors may go static. You have many details to look at before you keep going.
Terrell351
Jun 13, 2021 01:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Wife'sCar
Sep 5, 2015 08:58 AM
junkcltr
Jul 22, 2005 11:35 PM
