Mounting fuel cell for nitrous, need help
Old Jan 17, 2006 | 05:30 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
I got my new fuel cell that I'm going to use for my nitrous setup. I dont know what I was thinking when I planned it out but I had figured I could mount it flat. Now I have to come up with a way to mount it elevated and at a down ward angle. Here is a picture of the fuel cell and where I want to mount it.
Anyone got any ideas?
Old Jan 19, 2006 | 04:47 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
Anyone?
Old Jan 19, 2006 | 05:58 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
is that thing even a gallon?
Old Jan 19, 2006 | 06:53 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
what kind of pump are you going to use? **off sub** i was thinking about the same thing but useing propain because it has an oct of 115
Old Jan 19, 2006 | 07:44 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Where is the fuel pickup and where is the vent? Or is the cap vented?
Old Jan 19, 2006 | 07:54 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
It's a 2 quart cell. It's just enough for 1 maybe 2 runs with a 150 shot. I'm going to use a carter, inline, rotary vane, 6 psi pump that flows 72 GPH. Believe the number on it is 4070. I Figure the MAX free flow rate is 72 gph so the following numbers are all high estimates.
72 gallons per hour = 1.2 gallons per minute = .02 gallons per second. Then figure I should run low 12's to high 11's, plus I'm using a window switch which means I won't be flowing the entire time. At 12.5 seconds per run, that's exactly .25 gallons per run or 1 quart. That would technically be enough for 2 runs. I can always upgrade o a bigger cell later.
Edit: The vent is the tube coming out of the top in the back and the outlet is at the front. There is no actual pickup tube. The outlet has a petcock and is slightly sumped but I still need to angle the cell a little.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
89fast5oh
Sep 27, 2015 09:04 PM
z28_AJ
Aug 27, 2015 08:59 PM
