NOS Plate System Microswitch
Old Feb 26, 2006 | 02:02 PM
Brianmitchell's Avatar
Car: 92 Z28
Transmission: it has one
I was intalling the NOS TPI (05151) system on my car when i got to the mounting of the microswitch. I have no idea where to intall it so that wide open trottle activates it. The instructions are very basic and does not say excatly where to mount it. Does anybody have any pictures of how they mounted theres on the trottle body or have any sugestions?
Old Feb 26, 2006 | 06:58 PM
NOSFEDGTA's Avatar
throw that one out, and got to www.jimmy-jams.com and get one
Old Feb 27, 2006 | 07:00 PM
Fastmax's Avatar
Car: 89 IROC
Engine: 350 CI Tuned Port
Transmission: Automatic
Axle/Gears: 3:45
switch
I gave up on mine and went with an electronic activation switch that wires into the tps. Works excellent!
Roy
Old Mar 2, 2006 | 05:12 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I know this is an older post, but just go to any electronic store, (like radio shack), and they will have a bunch of different switchs.
Old Mar 3, 2006 | 12:07 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Here is one way to do it. On my stock throttle body I had the bracket attached to the lower right TB bolt.
No big deal really. You just bend the bracket as you need to ensure that the switch is engaged at WOT.. no rules, no prefab... just bend/cut/twist that sucker to where it needs to be. I could have done it a bit cleaner I guess but it is functional.
I agree that the TPS type switch based on voltage is a nicer way to go but the microswitch is cheap and it works.
Cheers!
-Schultzy
Old Mar 19, 2006 | 06:39 PM
BadGirlIROC's Avatar
Car: 87 IROC-Z
Engine: 355 carb'd
Here's the Jimmy Jam's WOT switch
Hotrodboba400
Dec 10, 2019 07:07 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
Kenwood
Sep 4, 2015 05:50 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
