newb 305 build
Old Feb 26, 2006 | 10:05 PM
ryane88's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
newb 305 build
I am adding some power to my 305
and i've gotten so far on the planning
K&N filtercharged (installed)
Not decided on the throttle body yet
Edelbroc Performer Intake from Jegs i dont have to mess with the EGR (i am getting the bore machined to 2" at a local shop)
I am going to try and nab some 081 tpi heads
an LT1 cam off ebay (not sure here)
Hooker 2 5/8" long tubes
3" Y pipe to magnaflow(installed) and cut outs
then edelbrocs 67gph Fuel pump from summit... which i think should be fine.
i already have some type of accel ignition system... i need to look yes i know
my rear end due to abuse from the shift kit is worn to hell in back... not sure where to go in that direction...
and yes i've been told... building a 305 is a waste of time
but that just fuels the need to do it
plus my parents would kill me if i brought a 350 block home randomly
Old Mar 2, 2006 | 11:40 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Are all those parts you listed stuff you already have or stuff that you plan on getting? If you end up getting another rear end, try finding one that has some steeper gears (if you don't have some now). That alone will make you feel faster.
Old Mar 2, 2006 | 06:05 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
67 gph pump = 255 lph pump and you can find they cheaper on ebay,( got mine for 70 with install kit)
Old Mar 3, 2006 | 08:06 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Should this be in power adder ?
Anyhow as far as gears , if you already have low gears an increase will be the biggest seat of the pants feal .
What were you asking ?
Old Mar 3, 2006 | 11:19 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Well I'll be the first to say get a laptop and start tuning.you're going to need it with those mods.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
Reborn756
Sep 4, 2015 03:42 AM
makaveli09
Aug 12, 2015 09:07 PM
