It's alive. IAC tech.
Old Feb 26, 2006 | 11:57 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
For those of you who know me from way back,....I built a new blower motor for my superamed and vortech charged GTA. It was my first complete engine build. Did eveything myself. It was done in may of last year, but ran like crap...I finally got the time to get it running. It's on the road an everthing. Runs well over 1000 rpms. Few questions about the necessity of the IAC and cpu. It seems to be screwing up my idle. When I drop it into gear, the idle drops to 600rpms and the i only get 8 inches of vac, so it runs crappy. Can I open and then disconect the electric to the IAC all together? when i bump up the minimum idle,...it seems as if the cpu want to keep it lower, so my idle in nuetral is only at 800rpms with 10-11 inch vacuum (because of the cam). But it runs good in nuetral at idle. I adjusted the TPS too. I am runnning 12 degrees initial timing right now. any advise on how to get the idle up a little when it's in gear. I guess i could raise the initial timing more, but i don't want to go much higher...it is a pretty big cam for the cpu, like 226/230's duration @.050. I'm thinking holes in the trottle blades, or no IAC or soemthing. ideas?
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
