External Wastegate Vacuum/Boost Reference Line
Old Mar 10, 2006 | 03:16 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Guys, should the wastegate reference line be connected to the plenum or before the throttle blades, i.e. on the ducting between the turbo and throttle body?
Willie
Old Mar 10, 2006 | 04:04 PM
Dan W's Avatar
From Maximum Boost (Corkey Bell): (edited slightly for wordieness)
"Essentially, three choices exist compressor outlet, plenum entering the throttle bodies and intake manifold. Each has merit and problems.
Compressor outlet:
best control over wastegate in regards to response and ability to consistently control boost to a given value. The bad side is that torque -curve rise will suffer slightly as this source will create the earliest possible wastegate cracking point. This early cracking point will offer some relief thermally because the entire system will virtually never see more boost than the basic setting of the wastegate. This can be important in avoiding a quick heat soakin of the intercooler.
Intake Plenum:
will wlightly imporve boost response since the turbo is free to ake all the boost it can until the pressure reaches the signal source and is transmitted to the wastegate. The fact that the turbo is free to make a brief spike of boost will cause the intercooler to be hit by a greater slug of temperature. Greater temperature is always to be considered a negative. For a blow through carb system where the wastegate and fuel pressure regulator must see the same signal simultaneously, the plenum signal source is best.
Intake manifold;
only when turbo response is of the highest importance and the short blast of extra heat can be tolerated or ignored.
All things consided, heat should be the controlling factor. Unless unusual circumstances dictate, hook the signal to the compressor outlet and call it a day"
Old Mar 25, 2006 | 10:52 AM
Willie's Avatar
Excellent info Dan! Does it make a difference where on the "boost" tube to connect the wastegate reference line too? My boost tube is rather long, considering it runs from the compressor to the intercooler, then to the TB. Should it be closer to the compressor or throttle body, or does it make a difference?
Willie
Old Mar 25, 2006 | 03:52 PM
Dan W's Avatar
Based on what he is saying, I'd interpret that as the closer it is to the compressor on a typical setup, the better.
I have a pair of PT-51's (not installed yet) that have a port presumably for the waste gate signal installed in the compressor housing from the manufacturer.
Attached Thumbnails External Wastegate Vacuum/Boost Reference Line-turbo-parts.jpg
customblackbird
Oct 1, 2015 04:30 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Nick McCardle
Sep 10, 2015 08:36 PM
