second fuel pump problem
Old Mar 11, 2006 | 07:03 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
When my car is running both luel pumps my car stumbles and dies after I floor it and let off quickly. If I unhook my second fuel pump it does not do this.
I have a Vortech supercharger with FMU if this helps. It also is a MAP.
Old Mar 12, 2006 | 09:27 AM
Engine: 400 and 350
anyone?
Old Mar 12, 2006 | 09:40 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
More details please. Are your pumps in series or parallel? What is your nominal fuel pressure and does it change when the problem occurs?
Old Mar 12, 2006 | 03:53 PM
Engine: 400 and 350
I have the original pump in the tank and the new one that came with the kit mounted infront of the strut tower. The pressure with just the stck pump is reading 38psi. This is due to the new pump restricking the flow. When I turn on the new pump pressure is set at 50psi and that is where it is at.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
