Best plug to run with supercharger
Old Mar 22, 2006 | 04:11 PM
1fas92's Avatar
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
I am trying to find out what would be the best plug to run on my car.
Here is a little information:
1992 Z28
supercharged 383, 210 afr heads, tpis mini ram, long tubes with dual exhaust & fast ecm. I have autolite's in it now (not sure which one, without looking)
I want to know what to use at the track & use on the street. Becuase on the street i was told to use a different plug vs the track.
Thanks,
Robbie
1fas92
Old Mar 24, 2006 | 07:23 AM
blown3rdgen's Avatar
I run ngk's
BKR6ES -I believe. I too have a 383 w/afr's and procharger (10lbs)
Depending on boost and horsepower your heat range may vary.
Matt
Old Mar 24, 2006 | 02:59 PM
1fas92's Avatar
Car: 1992 Z28
Engine: Forged LS3
plugs
Here is a little info I got off of other turbo sites. The guy that installed my fast system build's turbo Buicks. Well he said to run this plug, so I going to try it this weekend. But thanks for everybodys help on this one!
R5671A-10 NGK V-POWER RACING PLUG 5820
R5671A-7 NGK V-POWER RACING PLUG 4091 Hotter plug
R5671A-8 NGK V-POWER RACING PLUG 4554
R5671A-9 NGK V-POWER RACING PLUG 5238
R5671A-11 NGK V-POWER RACING PLUG 6596 Coldest plug
Old Mar 24, 2006 | 07:32 PM
That is a really cold plug. I tried that "racing" series too, but the car actually liked the plug with a slightly projected tip.
eightsixseven
Dec 16, 2024 01:50 PM
rocn7roc
Sep 21, 2021 02:16 PM
apo_bailon15
Mar 28, 2016 05:20 AM
1989formula5.7l
Aug 17, 2015 02:56 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
