2.8L Nitrous?
Old Mar 25, 2006 | 11:20 PM
Cadmaro's Avatar
Car: 85 Camaro
Engine: Cadillac 500
Transmission: TH400
Axle/Gears: 9 bolt
2.8L Nitrous?
HAs anyone put nitrous on a stock 2.8l ? i was thinkg maybe a 50- 100 shot to pep up my 85 camaro might work with a little timeing retard and cooler plugs. what do u guys think?
Old Apr 7, 2006 | 01:07 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
My .02: Stay with stock plugs, pull 2 degrees of timing and run a 75 shot. This should be a good comprimise between to much and too little to make a difference. I love running the smaller shots like this because a 10 pound bottle just seems to last and last. Don't get greedy with the juice and your 2.8 should be fine, make sure the ignition stuff is all fresh before you start or you may end up with a huge headache.
Old Apr 9, 2006 | 10:46 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
ZEX makes a nice kit that they use and it pretty much takes most of the thinking out of it. You get the adjustable one from 55-100 shot and I have seen these run on simalar v-6's and they seem to work really well.
bplessy
Sep 30, 2015 12:14 PM
88rscamar0
Sep 23, 2015 09:08 PM
64goatman
Sep 9, 2015 01:09 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
