NOS?
Old Sep 12, 2000 | 10:08 PM
92RSCAMARO's Avatar
NOS?
I am thinking of NOS to make my car insanely fast.what would be a good set up for my application and how big of a shot should I use so I wont have to worry about blowing my motor?100?or If it can handle more SAFELY tell me.
Chevy 355 cid chevy orange and lots of chrome
Vortec heads ported polished and milled also the exhaust ports are ported.
Edelbrock #7116 performer RPM intake also ported to match heads.
Keith black 12cc 9-6-1 compression flat top pistons.
Comp cams extreme energy #262 roller cam.
Pro jection 1 inch tbi adapter.
14 x 3 open air element
Accel 8mm superstock wires.
Holley 670 TBI.
Old Sep 12, 2000 | 11:08 PM
91vortecRS's Avatar
your motor can handle 150 shot of NOX , with out any problems , a production motor will take 100-150 all day long with any harm . so spray that puppy and hold on
1991 RS 305 ci
vortec heads
compucam 2031 cam
edelbrock 1405 carb
edelbrock 2116 intake- (vortec)
ASCD - SS hood
headman headers - aluminum coated
no cat - 3" exhaust-flowmaster
march under drive pulleys
lakewood adj. LCA's
etc.... etc... etc..
13.46 @ 105 mph
2000 Grand Prix GTP sedan
http://community.webtv.net/RS91NOX
Old Sep 12, 2000 | 11:36 PM
1QUICKRS's Avatar
You can safely go above 100 hp, just make sure you keep an eye on your fuel pressure and check your plugs. The stock TBI pump is pretty weak and may or may not deliver enough fuel. I am currently running 120 hp jets in my '92 RS with no problems. Experiment with timing fuel pressure and jets and you should be just fine. Have fun!
Old Sep 19, 2000 | 06:55 PM
Formula-91's Avatar
Make sure you get a kit that is adjustable higher than you initially plan to go. For example, if you buy the NOS Sniper kit, you're maxxed out at 150hp. I'd go with the cheater kit, that runs from 150hp to 250hp. With the KB pistons, I wouldn't go much above 180, but you might want the headroom if you decide to go forged. Get a set of plugs that are one step colder than stock, and NOT platinums. Pull a couple of degrees of timing out, and squeeze.
91 Firebird Formula. Converted to carb. Holley 750. Forged Flat top pistons. 10.5 to 1 compression. ZZ-9 Cam. Ported L98 Heads.
150 shot NOS, 700r4 w/ 3000 rpm converter and 3.73s in the back. Headers w/ full dual exhaust. 27.5 inch McCrearys. (free slicks)
12.98 @ 106 Natural,
11.83 @ 113 NOS.
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
