Which are the better injectors
Old Oct 2, 2000 | 02:17 PM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
Hello,
New to the MSG board.
I Have a 92 Z28 conv.TPI 305 with a sn2000 Paxton. stock 19lb injectors, fuel pressure set at 59psi, gose to 63psi at 8psi of boost.
I believe I need to upgrade to 24lb injectors
and have my prom recalibrated.
Which Injectors should I go with
BOSH or MSD.
Reliability and quality are most important.
Thanks, Your advice is appreciated
Louis S.
Convertable
92 Z28 305tpi Paxton
Old Oct 2, 2000 | 04:23 PM
Guido's Avatar
Car: 2000 Trans Am
I went with SVO injectors. They are a bosch injector I believe and are pretty cheap if you buy them through summit or jegs.
Are you sure a #24 is right for you? Thats sounds pretty big. You would defenitley need some PROM work so that it would not run so rich on you.
Good luck
-86 IROC
Vortech stuffed EFI 406 in progress
-=ICON Motorsports=-
Old Oct 3, 2000 | 07:34 AM
Good luck
[/B][/QUOTE]
WHAT INJECTORS SHOULD I RUN?
My spec's:
305 auto 2025 stall
Paxton 8psi w/water injection
52mm T/B
AS&M Large tube runners
ported & polished upper Intake
ported & polished lower Intake
gasket matched & checked w/a borescope for perfect fit
1.6 roller rockers
slp headers
Gale banks 3in exhaust
random 3in cat
19# injectors fuel pressure set at 59psi
My o2 runs at .780 to .813 at power
Timing is at 29deg at power
MY Latest Dyno #'s:
323.7hp at wheels
365 tq at wheels
Thanks for the help
Louis
Louis S.
Convertable
Old Oct 3, 2000 | 08:15 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Louis,
I run a setup very similar to yours (check out the link in my signature). I run 50 psig (at no vacuum) and about 55 psig at 6 psig boost. My O2 readings are approximately 950mV with injector pulse width up to 16mS. And this is with stock 19# injectors. It sounds like your pulse width is too narrow. Do you know what it is?
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://www.ozemail.com/au/jca69/mods/williesz/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Oct 3, 2000 | 10:03 AM
Originally posted by Willie:
Louis,
Willie,
I looked at my last runs and my pulse with is running at 12.4ms.
Who did your prom calibrations?, and was it done on a dyno or just by a list of your mods.
By the way NICE car.
Hopefuly soon I will have a site with my car and pic's
Louis
Old Oct 3, 2000 | 10:43 AM
Willie's Avatar
Louis,
My prom is a TPIS Level V.
Although 12.4mS is good for a normally aspirated engine, it is not enough for the mods we have. This is the pulse width I record without my supercharger and the resulting O2 sensor readings are in the 900mV range. When I run with the blower, the pulse width increases to 16mS, which sustains my 900mV+.
Based on my results, I would have to conclude that you do not need larger injectors, but a properly tuned prom.
Willie
[This message has been edited by Willie (edited October 03, 2000).]
Old Oct 4, 2000 | 12:22 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I talked to a shop www.musclecars.se they have built a 383 with trickflow heads 1.6 RR and a 9 psi ATI and they have the stock prom and stock injectors.
I leaving my car at this shop next year...
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
