need help with my supercharger
Old Mar 31, 2006 | 10:49 PM
kickass92z's Avatar
Car: 92 Z28/86 T/A/98 R/A T/A
Engine: 355,355,LS1
Transmission: T-56,700r4,T-56
Axle/Gears: 3:73,3:42,3:42
I just finished my first supercharger system, and things aren't goin right. First off it blew the lower intake gasket. I fixed that reset the timing and tried it out. The car is now falling on it's face it jumps out like it is gonna run fine and then just lays down. The s/c is a powerdyne I am running around 6psi. It is on a TPI ( SPEED DENSITY ) 355. The car was amazing till this was alot faster on motor. B-4 it blew the inatke gasket it seemed to run better. Any help is appreciated......
Old Apr 2, 2006 | 06:41 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Sounds like you might be going lean. Have you done anything to your fuel system when you installed the supercharger?
Old Apr 2, 2006 | 07:11 PM
kickass92z's Avatar
Engine: 355,355,LS1
I have upgraded the fuel system i AM RUNNING ABOUT 40PSI AT IDLE AND AROUND 50 TO 55 AT FULL THROTTLE.
Old Apr 3, 2006 | 12:52 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
We need more detail . By upgrading the fuel system does that mean an FMU, 60# injectors, etc. Do you actually see the amount of boost your suppose to?
Do you have a wideband?
Old Apr 5, 2006 | 08:16 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I had this same problem on a mustang. It turned out the map sensor would go nuts if it saw boost. What we did was put a one way valve in the vacuum line.
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
