Anyone have N.O.S. wet TPI system? 5151
Old Sep 30, 2000 | 12:52 AM
89ROC's Avatar
I know this system is only designed for 150HP max. This speed shop told me that it can be pushed up to 175 max. It would require 82 Nitrous jet and 65 for fuel. Instead of 70 Nitrous jet and 53 fuel.
How far have you pushed it? What would be stopping me from making it a 200HP shot?
Thanks!
AKA Pony Punisher II on all other boards.
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
A4, bone stock except for the Flowmaster.
Old Sep 30, 2000 | 03:15 AM
Omar's Avatar
I have this system, but I have never jetted it above 150HP. I think you should be ok for 175HP. And i believe the only restriction would be in the Super Powershot Solenoids. You would probably have to upgrade to the Cheaters, or whatever the next level is.
1989 IROC-Z 5.7L
Old Oct 11, 2000 | 05:33 PM
Formula-91's Avatar
One of my friends did exactly what you're talking about. He had to upgrade to the Cheater solenoids. The smaller ones wouldn't flow evenly thru the larger jets. The Cheater solenoids are also good for a 250 shot, so if you want to go above 175, you just need to change jets. I'd be careful above 175, though. If your pistons aren't forged they won't hold up for long.
91 Firebird Formula. Converted to carb. Holley 750. Forged Flat top pistons. 10.5 to 1 compression. ZZ-9 Cam. Ported L98 Heads.
150 shot NOS, 700r4 w/ 3000 rpm converter and 3.73s in the back. Headers w/ full dual exhaust. 27.5 inch McCrearys. (free slicks)
12.98 @ 106 Natural,
11.83 @ 113 NOS.
Old Oct 15, 2000 | 12:13 AM
Aaron88GTA's Avatar
Does anyone know if you can buy just the plate from this kit? I want to convert to the plate from the fogger nozzle I am using now.I think it may be worth a few more ponies.
Thanks,
Aaron
Old Oct 15, 2000 | 05:05 AM
Omar's Avatar
yes, you can buy just the plate. It is about $120.
1989 IROC-Z 5.7L
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
