Need fuel pressure regulator
Old Apr 2, 2006 | 05:12 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
Need fuel pressure regulator and fittings help
My 350 with ProCharger has an Edelbrock mechanical pump (1711) that's putting out 13-14psi at idle. I can't even set the float level, gas shoots everywhere when removing site plug and lossening float screw.
I've only had this car for a week so I'm not sure what size the lines are. I know that I need the regulator but don't know what I would need as in fittings to hook it up. The 90 degree fitting coming out of the pump 1/2" outlet is reduced in size before it goes to the carb. Could this be a 3/8" fitting?
So far I'm thinking of getting an Aeromotive universal bypass regulator (13301) because it has 3/8 inlet/outlet(s) and boost reference. I need some fittings too, not sure what to get. I know that I don't have a return line so I'll need some plugs for this regulator also. Will the regulator work without a return line?
Does this sound right? Sorry, but this is all new to me. Thanks.
Old Apr 2, 2006 | 10:03 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
I decided to go with the following:
Aeromotive 13301 regulator
1 foot -6an hose, -6an ends
2 3/8" NPT plugs
1 3/8" NPT to -6an straight fitting
1 3/8" NPT to -6an 45 degree fitting
Hope it works
Old Apr 3, 2006 | 08:02 PM
nightrider87's Avatar
the regulator won't work without a return line.
Old Apr 4, 2006 | 09:06 AM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
I guess I'll just add a return line if it doesn't.
Old Apr 9, 2006 | 03:34 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
I added a return line, so far so good.
Now I just need to learn what the differences (if any) are when tuning a supercharged carb. Earlier I took off the hat and adjusted the float levels and adjusted the idle mix screws. I also turned the idle down to around 750, it was around 900-1000 before.
I'm thinking about getting a wideband so I down blow things up. Right now the car will run fine unless I give it WOT. It stumbles a lot and won't take off until higher rpms, like over 3500-4000. There's a pink cam on the primary and secondary. I feels like it's getting too much fuel when the secondary shoots. Both shooters are 0.031
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
